Cant get my feed back online
mjbjr
Macon,Ga USA
Had it up the other day and it worked sporadically, but now i cant get it to even come back online. I have audio on the scanner (sds200) but cant get it to go through RR
mjbjr
Macon,Ga USA
All that is coming across is about a 1/4 second of audio and a loud beep.
I'm hearing that as well. I think it's a reception issue. I have a couple of antennas being delivered tomorrow and I can move stuff around to get a better reception. The beep, I don't have a clue about it
Enforcer52
Lake Livingston, TX
Is the audio being feed over URL (ethernet) or with an audio cable?
What software are you using to stream?
Enforcer52
Lake Livingston, TX
Do you hear the same on the scanner, or do you hear the whole conversation?
I would double check my audio settings, are you using ProScan?
mjbjr
Macon,Ga USA
P25 I assume. I had it programmed for me. And it was working before I moved a few weeks ago. That's why I assume it's a location issue. P25 idk really
mjbjr
Macon,Ga USA
Once I get the antenna installed I will update. Thank you for trying to help. I'm appreciative. Happy thanksgiving
