Hey guys, newbie here.
I bought a used sds100 with main 1.06.00 sub 1.01.05. Whatever i did sentinel did not upgrade firmware. Is there any way to download & update firmware without sentinel?
You must use Sentinel to update the firmware.
Current versions of firmware available through Sentinel for the SDS100 are:
1.10.00 - Main
1.02.01 - Sub
What do you mean when you say Sentinel didn't update the firmware? Did Sentinel start and run? What error messages are you getting? Be sure of the following....
Be certain you have the latest version of the
BCDx36HP Sentinel Software (Sentinel version 2.02.01) . It shows a green icon when starting (not orange).
Be sure you set the target model in Sentinel correctly before updating.. from the top toolbar, click "tools", then "target model".
Are you putting the scanner in "Mass Storage" mode when connecting it to your computer?
Be sure you are using the lower,
mini-USB, port labeled "Charge", not the micro USB port.
Check your owner's manual at the bottom of page 10 and the top of page 11 for very clear instructions to upgrade your firmware and database.
The online manual is here:
