Cant hear anything but noise
Iz3k34l
OK so i bought a Kenwood TK-2107 VHF transceiver, i got the cable and software to go with it. I am able to program the radio to the desired frequency but it doesn't get anything but what i guess is squelch noise. Here is what a line of the program looks like:
Frequency QT/DQT
CH No Receive Transmit Dec Enc Bsy Shft
1 154.785000 155.85000 178.8 178.8 No No
Here is a copy of the county info:
Frequency Input License Type Tone Alpha Tag Description
154.78500 155.85000 KNFL698 RM 173.8 PL Gray SO A Grayson Sheriff Dispatch – Analog
Mode
FM
So any help is greatly appreciated, Thanks
WayneH
Forums Veteran
Super Moderator
Sitting in an airport somewhere
Before creating a thread please make sure to read the full forum name and its description. Next time take a few more seconds to scroll down to the Kenwood forum. The Scanner Programming Software forum is for scanners only.
Thread moved to Kenwood.
kma371
Frequency QT/DQT
Mode
FM
Unless it's a typo, the PLs aren't the same
Sent from my iPhone 4 using Tapatalk
Av8tor56
Roswell, NM
Ok. It's only a guess but you either have a very loose squelch setting (opening at .1 uV or lower) or one of the radio is stuck in monitor. Can you look at the program and see what the key assignment is? one button is usually set for monitor. if there is one then try resetting that button. If that doesn't solve the problem then you my need to put it in tuning mode and tighten the squelch.
Iz3k34l
there is a "moni key" which has several setting off, sq off momentary, monitor, monitor lock which i tried using the sq off momentary and off setting only.
I dont see that it has a tuning mode, unless im just missing something.
Av8tor56
Roswell, NM
Ok. Try this: Take the antenna off of the radio. If the noise goes away then chances are your squelch is too loose. If the noise is still there you have a problem with the radio itself and you may need to take it in for a tech to look at.
ramal121
Sonoma, CA
This is a repeater split and you will need to talk through the sheriff's repeater to communicate radio to radio. Are you authorized to do this???
It also looks like a mixed mode analog/P25 repeater. If they normally use P25, you will not be able to receive them with that Kenwood radio.
Iz3k34l
Yes, i am LE
I was afraid this was going to be the case, the more i am reading about this radio the more i lean to this conclusion.
I am probably going to be getting a Motorola XTS-2500/3000/5000
Thanks for everyone's help
