Can't initiate P7200..says "Radio Locked"
wanabe
Picked up a P7200 from Fleabay for cheap last week..and when I do the 3 finger procedure on the radio to get it into program mode, it comes up"Radio Locked' Any idea idea on how to get around that? It won't even put the radio into program mode. If anyone has any ideas, I would be grateful, Thanks
wanabe
That’s it Forts! Thank you very much! Through out the years on these forums you have helped so many people out with their questions and problems about their radios! I really appreciate it! Thank you again!
wanabe
Forts, I seem to be running into a problem. I can get out of the locked status, but when I turn off the radio and do the 3 finger procedure, it won't initiate and comes up locked again. I just cant seem to get this radio into "Program" mode. Any ideas? TIA
Forts
Ontario, Canada
Could be any number of things.. I've always had mixed results trying to force them into program mode. What firmware is in the radio?
wanabe
And it beeps non stop every 5 seconds...I've had 4 P7200s in the past and none of them ever beeped like this... and I could always get them into program mode. Stumped...TIA
BMDaug
I am licensed…
Central Colorado, USA
Are you holding all three side buttons during power on with the programming cable already connected? The locking on power up is normal if the personality has ‘lock status’ and ‘lock’ boxes ticked in power on options…
-B
Forts
Ontario, Canada
What are you trying to program with... Programmer or RPM? What version? I've had a few that were just stubborn as hell... and I had to use a combination of software to get them to comply. The last 7200s I dealt with had really old firmware, and the only way I could get into them was with the command line stuff to update boot/burn app then the firmware. Then I had to use an older version of RPM (6? I think..) to get in a newer old firmware... then finally RPM14 to bring it to current. It was a real chore.
wanabe
Thanks fellas..Yes I’m holding all 3 down as I power up (even though RPM 14 says in the help notes to only hold PTT down on the P7200). And I’m using RPM 14 Forts. It’s not budging. Thanks for your help.
wanabe
Yea, Fleabay had a bunch of P7200s, still in their boxes up for auction a few weeks ago. Maybe some of you saw them.
merlin
DN32su
After pressing "M" you mut press the top side button within 1 second. Works like a toggle to lock or unlock the keyboard.
That function can be turned off with RPM.
Still, to enter programming mode, you need to hold all 3 side buttons and power up.
