Can't program a Retevis RT27V MURS handheld
poltergeisty
Truth is a force of nature
Banned
RLG, Fly heading 053, intercept 315 DVV
Got a programming cable and installed the universal USB driver. Went to the programming software and nothing. In device manager it says I need a driver. I tried the other USB drivers they have and I can't even install them. Even right clicking the inf file to install I get an error. You'd think the universal USB driver would be what I need.
Things I tried:
Turned the radio on, installed the driver, rebooted the computer. Nothing.
Tried in VMware. Same thing.
Tried on a laptop. Same issue.
It's like I don't have the right USB driver for the cable. Cable says Retevis on it so I'm assuming it's correct. Should be.
Running Windows 7 64. Here's the download link: Resources Center
ko6jw_2
Santa Ynez, CA
This main problem is that your radio ONLY operates on MURS channels. It cannot be programed for anything else.
poltergeisty
Banned
That's not my question at all. I specifically stated I could not get the USB driver to work and as a consequence I can't use their provided software to change tones and an apparent DCS encrypt option I wanted to test to see what that was. You can download the software for this radio right there in the link.
Anyone here use the software for these radios?
ai8o
Brachiating Tetrapod
Lexington, NC
You have an FTDI cable/driver incompatibility problem.
Lots of CCRs have this problem.
If your programming cable has a counterfeit Prolific chip and are using the device driver automatically installed by Windows, this device driver is intentionally incompatible with unauthorized copies of the Prolific chip.
For a further info on this problem, go to:
[Cables & Drivers - Prolific & FTDI
poltergeisty
Banned
Thanks! That was a huge help. The Prolific driver on that website worked. Yet the version they give on the Retevis website doesn't. Does this mean the cable I bought on eBay is a counterfeit? Here's a picture of the cable.
KD8DVR
Columbus, Ohio
YES... that cable contains a fake Prolific chip. A lot of people buy FTDI chipped cables now. Me, I fitted out all my cables with cp-2102 chip kits and also eliminated issues.
jaspence
Michigan
Connecting the radio, turning on the radio and then installing the driver last may be your problem. I have at least 10 different programs for my radios, and they all required installing the driver and then connecting the radio and turning it on. Uninstall everythng for the radio, restart the computer, and reinstall in the correct order and you should be able to make you adjustments.
poltergeisty
Banned
I tried both methods. Once on my desktop, then in VMware, then on a laptop.
