Can't receive Dallas Public Safety TRS
VoicesInMyHead
Can anyone near Paulding County verify if you can receive the Dallas Public Safety trunked system? I've tried the frequencies in the database and rebanded frequencies another member found for me but I hear nothing. Perhaps I'm out of range?
k8484
GA
Im fairly close, ill give it a shot tomorrow. If they were on warrs i'd know by now.
k8484
GA
Can't pick them up out here. I was able to pick up a constant 1 bar signal on the DB freq's, got a fluctuating 1-3bar signal on a -15 reband of those freq's, but I'm not close enough. I can confirm that they aren't on the WARRS that Haralson, Carroll and Heard are on though.
VoicesInMyHead
I appreciate your tests. I suppose signal is my same issue. I'm in south Paulding county, maybe two files from the Douglas county line... I guess they just don't reach this far.
Thanks, again!
N8IAA
Fortunately, GA
What antenna are you using on the 106. You may want to try the RS 800MHz antenna. And turning down the squelch will help you to receive the signal better.
Larry
