I'm fairly comfortable with Unitrunker and DSD+, and I've used the programs successfully for a number of systems. However, I can't achieve greater than a 67% decode rate for one of the local P25 Systems (https://www.radioreference.com/apps/db/?sid=8227). The system is a 5 or 6 tower simulcast system, which makes things fun. It is mixed Phase 1 and Phase 2.
Though the decode rate is marginal, UniTrunker seems to catch all of the calls (there is an EDACS system with mostly the same traffic, so I have a great reference). Unfortunately, the voice decoding in DSD+ isn't good, hence why I'm trying to figure out what I might be able to do to achieve better signal/decode.
Today, I drove to the central tower site, and -- even right below the tower -- I could not achieve greater than 67% decode. The DSD+ voice decode was pretty good near the tower but nowhere near perfect. Is simulcast multipath really that sensitive?
By the way, my WS1080 does great with this system. The "T" indicator is almost always solid, and the voice decode is great. The Phase 2 traffic is amazing in clarity -- even better than the phase 1 (I assume this has to do with the user radios generally being newer and better). (Most of the traffic is Phase 1, I realize DSD+ and Unitrunker don't handle Phase 2).
I've tried a number of antennas, including:
- RTL antenna mount with no antenna
- The short black and telescoping RTL stock antennas
- Paper clip
- Touching the antenna mount stub with no antenna (my body seems to be a good antenna)
- Yagi 800-900MHz (http://www.amazon.com/gp/product/B00L3ZRF9A)
- TV antenna
- TV antenna with preamp
- Stock WS1080 antenna
- ~ 850MHZ whip antenna
I've also played around with the various gain settings.
In SDR#, the control channel is strong, topping 0dB with a noise floor between -25 and -30.
I've read dozens of threads and webpages regarding decoding, simulcast problems, etc., so I'm not looking for you to repeat the basics. I'm wondering if there is something specific about this system that's preventing me from getting a better decode, perhaps relating to the Phase 2 capacity. Also, if anyone has any experience with this system, it would be awesome to compare notes. I'd hate to give up on this, because the audio quality is amazing on my portable scanner.
Here's an example of the decode log file: https://dl.dropboxusercontent.com/u/14976381/P25 Signal Decode Log Sample.txt . It seems to jump between 65% and 68%. There are no error "e" lines.
- Paper clip
- TV antenna
