HP-1: Can't Update
#1
Not the best at the technical stuff so thanks for checking out my post. Have a HP-1 that I'm trying to update through Sentinel. If I Click "Update Firmware it says I have the current version of Home Patrol which shows 2.05 in the unit. Doesn't show 2.05.3 just 2.05 but the real problem is when I click "Update HPDB" I get the same message saying I have the current version of Home Patrol but it's been doing that for 3 months and it shows database version in Sentinel of 1-29-12. Any help would be much appreciated. Thanks in advance!
hiegtx
Dallas, TX
#2
Hi Ross
Welcome to RadioReference
From what you describe, it sounds like you have the older version of Sentinel installed. You can get the latest version here:
HomePatrolSentinel < HomePatrol < TWiki
Install the newest version, then update it's database, then see if you can't update the HP-1.
#3
Thanks so much for your advice Steve. I used the link you gave me and it worked perfectly and the HP-1 updated without problem. Never gave thought that Sentinel was an older version which turned out to be version 1.0.
Again, thanks for your support and quick reply.
