Cape Breton TGIDs
_DeS_
Cape Breton Regional Municipality
Hey Guys,
I was looking through the database and find that the bulk of Nova Scotia info is Halifax related. Any chance someone has a complilation of Freqs & TGID's available for the Cape Breton Area....
Thanks for any help....
_DeS_
mciupa said:
Have you visited www.marscan.com. ? :cool:
It has your region covered pretty well. I'll put up a link for Cape Breton and you can check if there is anything of value for you there. ;)
http://members.accesswave.ca/~scan/nscbrm.htm
Hey thanks for the reply...
I did visit that site, im good as far as police, I have the TGID's so im going to use those instead of the frequencies, I was more intrested in anyhting outside of police fire etc....
Thank you kindly for your help..
mciupa
DB Administrator
Moderator
You can also check Industry Canada's TAFL , that returns fourteen hits for Cape Breton
