Capturing airshow freqs
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
In the last couple of weeks, I've noticed several requests for frequencies for upcoming airshows. The wiki is a great place to develop such lists, since it can be built by any member. Once built, the list can be used - and updated- each year so that each year there is always a place to start.
If you have questions about building such a list please ask. I have a template or two already built, but whatever format you want to use is fine. Probably a straight list is the simplest kind, and it's easy to maintain. If you want to build a table so that you can use copy/paste functions (such as EZ Grab in FreeScan), that's fine too.
Don't forget to document your local trunked systems' activity, if there is any, that's relevant to the show. Itinerant and other freqs are also a possibility. Don't limit yourself to just the aero stuff - there might be other users, too. Document everything you can....best regards..Mike
