Car charger
thegmaniac
Can someone recommend a car charger for the g5 and is there enough amps/volts/watts/ohms/whatever to charge this thing thru a USB-A port in your vehicle?
bob550
Albany County, NY
Just search USB car charger and select any product of 3 amps or better. They'll just plug in to your existing cigarette lighter or power outlet. No need for wiring.
6Paul21
Florida
I use USB ports (2) in my car with no problems except you should keep batteries in radio and you have to turn radio off when you are not listening.. I use the second port to charge ear buds for the G4.
secfire212
-Not sure if this would go here or not..
A few leftover Ram Mount parts used to connect an amplified charger to a piece of plexiglass from Lowe's that's drilled to match the threaded screw mounts on the bottom of the charger. Volume level better, but improved even more with 8ohm Moto speaker plugged into it.
IAmSixNine
Dallas, TX
Any good Micro USB cell phone charger will work. The pager will charge up to 1A at 5V. So as long as your charger puts out 1 amp your good. OR you can get a combo usb adapter and a good charging cable. I prefer those types of set up so i can switch to mini usb for my SDS100 or my lightening cable for iPhone or USB C for my Android.
