Caught a rare handoff
Cape May,NJ
#1
I caught another handoff here in Cape May Empire 11 switched from ZDC51 Casino 285.400 to ZDC39 Snowhill 236.8250. I looked in up on Ron's list and its an aircraft out of Oceana Air Station in Virginia
Tech792
Central NJ
#2
There is also some army helos that use the ID EMPIRE that transit through NJ on a regular basis. But being you heard the handoffs on those ATC channels, it probably was a fixed wing.
TerryPavlick
Wallingford PA Villas NJ
#5
Rare for me based on my antenna setup. I don't get UHF air traffic control too much AND I SAW THEM (Yes I used caps) kind of a snooty remark
Justin - can you hear the controller on 127.700 Washington Center freq? If yes then monitor that when there is activity on 285.400 and you will at least hear the controller side.
Thinking back to remembering the activity on the radio - they were definitely fixed wing aircraft.
Terry
