Cavity Filter
RDowson
Does anyone make cavity filters? I need one with a sharp notch to reduce a strong frequency in the middle of the air band that is causing overload problems with my scanner.
I’ve looked at a notch filter or a coax stub filter but they aren’t sharp enough to stop other nearby frequencies being wiped out so a cavity filter may be my only option.
jwt873
Woodlands, Manitoba
Sinclair is commercial grade.. Not cheap for the hobbyist. Sinclair Technologies FP20107-1
What strong signal is in the middle of the air band? Is this an actual transmitter in your area (Like ATIS) or is it an image of some sort that might be attenuated without the use of a sharp filter?
StoliRaz
What frequency is yours on? I keep getting one lately at 125.000 on multiple scanners. It's probably interference from something in my house. I'm too lazy to seek it out so I just lock it out. Nothing on that frequency around me anyways
mastr
Thanks. Any idea how much they cost?
The example price above for the FP20107-1 is typical- BUT that is not an appropriate device for your need, it is exactly the opposite. The reject model is FR20107-1. Generally, the closer your "other nearby frequencies" are, the more costly the solution is going to be.
There are other makers, some probably cost less- Sinclair was just the first one I thought of.
RDowson
It’s VOLMET, so basically ATIS. It’s on 125.725
RDowson
125.725. Scottish VOLMET
G7RUX
You might like to try an O/C coax notch but with an odd multiple of quarter wavelengths length; you tune it so a harmonic of the notch falls on the troublesome signal, giving a somewhat narrower stop band. Worth a go.
Ubbe
Stockholm, Sweden
It happens the same with a cavity, that it will notch at multiples, so be careful if it is kept in line when scanning other bands than VHF-Hi. The length of the coax between scanner and filter are also crucial. I think it has to be a 1/2 wave electronic length or multiples of it. It always helps to use a cheap VNA to sweep filters and their coax harness.
/Ubbe
