CB Antenna compatible for BCT15 Scanner?
MXER
Elmore, Alabama
I've just ordered the BCT15 Scanner. And I'm wanting to install in the dash of my truck. I've already got the mount and everything installed. I'm wondering If I could hook it up to the CB Antenna instead of the AM/FM Antenna. Would it restrict the scanning power if I did so? I have a Cal Comm 3 foot (I think it's 3 foot) CB Antenna. My CB Radio is the North Star 9000 DX.
Bucko
Marietta, Ohio
You sure don't want to hook the two radio's on the same antenna if that is what you had in mine ( RF from CB would fry your scanner ). As for using the 3 ft CB antenna for the scanner only, low band would the only place you would see any results that would be good.
kf4lne
Bristol, VA
CB antennas generally suck for much of anything more than a few MHz outside of the CB range. Get a good multi band amateur radio antenna or a dedicated scanner antenna. The car stereo antenna will probably outpreform the CB antenna
