crazycanuck
- Joined
- Dec 17, 2006
- Messages
- 5
I am setting up a CB radio for my motorcycle. I haven't used a CB radio since I was a teenager and at the time I had built a few antennas. Unfortunately, I can't remember much of the theory.
I bought a Midland 75-822 Handheld. Today at Canadian Tire I bought one of those through the glass CB antennas. The arial is just under 22" tall. There is a metal base at the bottom of the antenna that is to be glued to the glass, and another metal plate that glues to the inside of the glass. Instead I was planning to mount the antenna on the rear plastic undertail fender. Would the signal travel through ABS plastic just as well as through glass?
Also, how do I tune the antenna? This antenna comes "pre-tuned", but has a lead that is about 8 feet long. I only need a couple feet of lead. How do I calculate the correct length of lead?
