cb antenna home/need of sealing?
Delivers1234
Modesto, CA
hi. so i have a CB whip with a mount similar to this on my roof. i sealed coax to the mount under the mount. Do i need to seal the antenna connection to the mount? the top part? They are on trucks etc and i don't see them sealed. Also the antenna to the mount nut connection? does that get sealed?
Not really.
The sealing is usually to prevent water intrusion into the coaxial connector and thus down into the cable.
It certainly wouldn't hurt to seal those, as water can get in there and cause some corrosion over time. It's not going to get to the coax via that route, though.
KK4JUG
GA
I would think an O-ring would work nicely.
slowmover
Fort Worth
I use self-fusing silicone tape. Maybe an overlay of something stronger as well. (Temflex).
Something that will be later cut away.
Both sides of mount.
