CB frequency licensed in Amarillo
Don_Burke
Southeastern Virginia
I was poking around in the ULS as part of an unrelated discussion and stumbled across KRC578 for the City of Amarillo which allows use of 27.235.
That's a CB channel that was a business channel prior to the expansion to 40.
Is Amarillo actually using it?
hiegtx
Dallas, TX
No idea if they were. But many cities, counties, and various public safety agencies keep renewing licenses for frequencies that have not been used for years, and more often decades, for Vhf-low channels in the old public safety range in the 30 & 40Mhz ranges.
Like this one:
That license is still active. I doubt that Glenn Heights does not have any radios that could use that band. But, by golly, they got themselves a license to do it.
nd5y
Wichita Falls, TX
Glenn Heights not only keeps renewing it they (whatever lawfirm handles their licenses) even narrowbanded half of it (only the base). It would have never originally had 11K2F3E.
Don_Burke
Like this one:
It's one thing to have a license with no equipment to use it. I suspect a phone call to Motorola would have them back in business in less than a week, possibly a day.
Amarillo appears to be paying for a license for a channel that no longer exists that would require equipment that has probably not been produced for decades. That would mean months of lead time and bushels of cubic dollars.
n7maq-1
Oregon
Amarillo got that call first in 1985, and it is AM. They only thing that is off is the 20 Watts. Like has been said above, it sounds like a rubber stamped process.
Jim
kc2asb
NYC Area
Jim
By 1985, 27.235 was already part of the CB band, ie channel 24, licensed by rule under Part 95. Could the 20 watts be correct and they are licensed for higher power under Part 90?
WB5UOM
If you dip down just a bit below 27mhz ,there are still numerous licensed stations for "broadcast auxillary pickup" to radio/tv stations that I bet (a few I know) hvnt been used in eons either, but they keep right renewing them
ecps92
Taxachusetts
Government Agencies - do not pay for renewals, only modifications or new applications thru the Freq Coordinators
