Cb Frequencys on programmable radio
E
etechonline2002
Guest
i have a programmable radio can i program a CB frequency and talk to people over it.
will it work or no
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
You must be new here. Stand by for a expert opinion from our resident know it all, Professor NJay. He will be here shortly to tell you what you are doing wrong. He'll quote Part 97 rules and regulations. He will explain type acceptance issues. He may even tell you that you put your shoes and socks on wrong. Enjoy. Everyone else does.
OP is Location: yorba linda wherever that may be. None the less, how would part 97 apply?
UPMan
In Memoriam
Arlington, TX
Most likely your "programmable radio" is an FM, UHF or VHF band transceiver (but knowing more specifically would certainly assist us in quashing your dreams :) ).
Technically, that kind of transceiver isn't capable of transmitting using AM modulation on CB frequencies. Legally, you can only transmit in the CB band on a transceiver that has been type accepted for such use (and your radio is almost certainly not). This is true even in the exotic location of Yorba Linda, California.
DX949
Banned
will it work or no
Like n9emz said...what type of radio do you have ! I could see it being done with an HF transceiver, You need a radio that will transmit as well as receive in order for it to work.
hope this helps.
And if ever you come back with your radio model ,you may get some ham's telling you to use it as a boat anchor or a door stopper,don't mind them,there just trying to show that there superior to you...lol.
The CB Guy is the one driving the Motorcycle.....the rest of them !......well........... you figure it out.
Welcome to the CB forum.
YouTube - Thomas Dolby - She Blinded Me With Science (2009 Digital...
trace1
EM73co
What kind of "programmable radio" do you have?
What frequency range does it cover?
What modes will it do?
Depending upon the answers to any and all of the above could determine as to whether or not you can or can not program "a CB frequency" into it. As far as being able to "talk to people over it", while that depends on several other factors as well.
If, and that may be a BIG "if", you can and are able to legally program those CB frequencies into it and there are others in close vicinity to you that have and use CB radios, or other modified equipment (legal or not), to transmit and receive in those frequencies then, YES, you may even be able to "talk to people over it".
will it work or no
Well, that depends upon any and all of the above... ;)
E
etechonline2002
Guest
Icom Ic-f21
i have a Icom Ic-f21 radio that i recently purchased.
trace1
EM73co
If you have the IC-21, a UHF handheld radio with TX/RX range 440-470MHz, then your answer is a great big NO!!!
You can not program CB frequencies (26-27MHz) into it.
trace1
EM73co
"One of Yorba Linda's most famous residents was the late former President Richard Nixon, who was born and raised in the city. The Richard Nixon Presidential Library and Museum is located in Yorba Linda."
DX949
Banned
Yorba Linda's most famous residents Richard Nixon ? Man........ i wouldn't want to see one of there worst resident.
trace1
EM73co
But then again,Richard Nixon did hang around famous people like Jackie Gleason, wich i believe was a good man,Jackie that is........He was a "CB" man.
Wonder what Nixon's CB "handle" was? Yep, he was a CB'er too. So was Betty Ford, "First Mama" or something like that, reportedly.
DX949
Banned
DX949
Banned
Edited out upon second thought.
For those who are dieing to know what was edited out.
http://forums.radioreference.com/rants/152379-just-too-good.html#post1117769
A classic,,,,,,,,,,,,,,,lol
The professor is at it again,,,,,,,,,,,lol
