CB Mic
corman007
My Radio was working now and it just has a high pitch squeal when I key it up and it's not transmitting Question for you knowledgeable gentlemen :) Does an older Panasonic CB require a special Mic? I have a Uniden 4 pin in it ?
It's receiving fine from my truck. checked antenna, Grounds, and Mic connections??? I'm at a loss !
The Radio is a Panasonic RJ-3600C base
Any help would be much appeciated.
KB0VWG
Was the mic working before on that radio or did you just hooked up this mic to the radio and did it start squealing? If its the wrong mic for the radio then will probably sqweel and have no audio.
kb0vwg
wqoi992
Michael
corman007
It's been in a closet for many years. This was the only Mic in the box. Only wiring diagram I found was on the Astatic site. Lokks like i'm going to go get one and crack out the soldering iron. This Uniden is definetly not going to work. No where else did I find any reference to Panasonic? Guess I chose to keep the odd radio? Can't believe how heavy it is!!! Hop the mic is the problem. Thanks for the reply!!
Skeith
Winnipeg, MB
Look up your radio's mic wiring on google and check the wiring of your mic.
Squealing usually happens when the Mic tells the radio to TX without disabling RX.
I also had an issue with a desktop realistic amplified mic on my Midland 77-892 I use as my base.
Although the Mic was wired correctly there was some power getting fed back through the amplifier circuit
into the radio via the hot audio wire. Caused the radio to squeal loudly when in RX. would key up and TX fine though. I installed a small 3v relay on the hot audio wire in the mic that connects the audio wire
when power is applied to the amplifier in the mic.
Works great now.
shortride
S.E. Oklahoma
It's not so much that it's the wrong mic, it's just that the connector is very likely wire wrong for that particular radio.
