I need to create a permanent installation station for my CB in my F150. But the interior is very limited because it lacks a center console and need your help. Does anyone else have a similar F150 and can you upload a picture of what you have for your CB? (I've checked the "Pictures fourm" but no luck)
Thanks!
I think it's quite the opposite. Center consoles generally hinder installation options by taking up a lot of interior space that could otherwise be used to mount a radio (or radio
s). Radio-wise, lacking a factory center console is a very good thing.
For your setup, the easiest and fastest way to mount it would be to screw (or bolt) the bracket right into the plastic below the HVAC controls.
For the best, most professional look; My advice is to build (or buy) a console box that fits in between the middle seat and the dashboard and mount your CB inside that (you will also have room to mount a mobile scanner in there as well
Alternatively, a third option is to make a simple wooden " T " bracket mounted on the floor above the transmission hump. A 1" x 8" pine board (available at any Home Depot, Lowes, etc) will give you plenty of material to make it out of. Basically you just measure and cut the horizontal piece to fit the length from the middle seat mount to the bottom of the dash, then attach a vertical piece (to the horizontal piece, either with screws from the bottom, or by using steel "L" brackets on the top side) that rests against the front of the middle seat. You can cut the vertical piece to whatever height you want (for example, mount the radio at the same height as your center arm rest for easy access while driving).
Good Luck
