CB Radio power cord?
nec445
I bought this at a yard sale for 5 bucks. I've never seen a power cord like this before. What do I need to buy for it? The wires are black, red, and orange. There's a good 2A fuse in there. I want to get some more of those. I'm not sure what else I need for it.
thanks in advance
jurrd87
San Clemente, CA
Hi Nec445, and welcome to RadioReference.
The closest thing I could find to help is this:
Cb radio assist - FixYa
I just looked this over... from the several automotive accessories (cb, radio, anything really) red is +, black is ground, and orange is switched 12v ie the ignition switch...
Sent from my DROID BIONIC using my fingers
jimbr1
Well, to answer the question, you could go to an auto parts store or Radio Shack for the fuses. Looks like you have a microphone and power wires, you need coax cable and an antenna to complete it- you may as well get an swr meter as well to match the antenna with your radio...cbtricks.com has info and schematics (note: orange wire has 1 amp fuse according to schematic)....good luck!
kc8kek
Ignition sense
I'm not familair with that exact radio, but on every other CB I've had that had an orange power wire (mostly from the 90's) the orange line is the ignition sense. If you hook the positive and negative (red and black, respectively) to a power source and the radio does not come on, then the orange wire needs to be on a positive source also. I usually just hook it to the same terminal as the red wire.
