You can relax and enjoy it, or, you can start reading up on antenna theory and look into just how complicated that can get. To chase down uniform low swr across a wider frequency range, among other things you can use a thicker antenna, i.e. moving from a whip to wider tubing. Many ways to skin a cat, but usually there are equally good reasons for the common way things are done, even if it is not perfect.
