CB with a G5RV?
Newark, DE
#1
Hi, I was wondering if I could effectively use a CB radio with a G5RV? I happen to have a G5RV for my Icom 718, and since it covers both the 10 and 12 meter bands, I figured I could use it on 11 meters. I was also wondering if there were any FCC regulations prohibiting such uses. Thanks.:cool:
Campbell County, Wyoming
#5
Most G5RV antennaes are horizontally polarized. This will be a problem talking to local stations (on CB vertical polarization is far more common). Vertical to Horizontal will create a loss of around 20 dB (call it 3-5 S units) On the other hand if you are listening for 'skip' the horosontal will quiet the noise quite a bit. after signals 'bonce off' the ionsphere, they generally are somewhat mixed as far as polorization goes. Give it a shot and let us know.
