CB with a G5RV?
Newark, DE
Hi, I was wondering if I could effectively use a CB radio with a G5RV? I happen to have a G5RV for my Icom 718, and since it covers both the 10 and 12 meter bands, I figured I could use it on 11 meters. I was also wondering if there were any FCC regulations prohibiting such uses. Thanks.:cool:
gewecke
Illinois
Nope! You can use any antenna you wish with your cb! :)
73,
n9zas
zz0468
A G5RV typically has lots of lobes and nulls in the pattern as you go higher in frequency, so it'll be hit and miss as to how well it works. But it sure won't hurt anything to try it.
wyShack
Campbell County, Wyoming
Most G5RV antennaes are horizontally polarized. This will be a problem talking to local stations (on CB vertical polarization is far more common). Vertical to Horizontal will create a loss of around 20 dB (call it 3-5 S units) On the other hand if you are listening for 'skip' the horosontal will quiet the noise quite a bit. after signals 'bonce off' the ionsphere, they generally are somewhat mixed as far as polorization goes. Give it a shot and let us know.
