CC channel baud rates
ahhh thanks, I learn new stuff every day :):)
oK with this info , what can I listen to with pro96com program?.. just 9600 baud CC's? or just APCO 25?
somme1916
Not sure what you mean about "what can I listen to with pro96com program" . There is a PRO96COM discussion group in yahoo:
http://groups.yahoo.com/group/pro96com/
One pgm that supports the pro-96 scanner radio is Win96. It lets you add/subtract info into the radio itself. There's probably other pgm's but I do not own a pro-96 so I can't tell you much about it. The pro96 does support digital trunking.
Again checkout: http://wiki.radioreference.com/index.php/Pro-96
http://www.radioreference.com/forums/forumdisplay.php?f=81
That's the Radio Shack scanner forum (who sells the pro-96).
Rob
mikey60
Oakland County Michigan
Pro96Com only supports the 9600 bps control channel (P25/APCO 25) at this time.
Mike
Thanks Mikey, thats what I was after.. wanted to try on MOTO & edac systems also , oh well need to do the tap one of these days hehe, All APCO 25 is 9600 baud?, prob another dumb question :)
loumaag
Silent Key - Aug 2014
Katy, TX
All Project 25 systems are 9600 bps (not baud).
