CDM 1250 Ignition / power question
Nasby
Ohio
I'm about to wire up a CDM1250. Is it possible to have the radio power on and off with the ignition?
I know with the PIN connector it will power the radio off when the ignition turns off but I can't get it to power back on without pressing the power on button each time.
If this can be done can someone point me in the right direction? In reading the CPS help under ignition sense, it doesn't look like its possible.
Thanks in advance!
KG4INW
Midlothian, VA
Yes, with it programmed to follow ignition, it will turn on and off without having to push the button. It's under radio wide configuration. If you've already programmed it for this, then perhaps there's something wrong with the radio?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Thanks in advance!
In the CPS: Radio Configuration ---> Accessory Configuration tab ---> bottom of the tab - Ignition Sense Type. There are four choices in the drop-down: Disabled, Follow Ignition Only, On/Off & Ignition, and PTT Disabled. You need to select On/Off & Ignition which will make the radio function exactly as you want.
Run a line from Pin 10 on the accessory connector to an ignition/accessory controlled source in the vehicle. Fuse it at 4 amps at the source end and you're good to go.
The radio will come on when the car is started or the key set in accessory position and then go off when the key is turned off. You will be able to turn the radio on without the key by pressing on the volume control. You will also be able to turn the radio off even with the vehicle running by pressing the same button.
