CDM 1250 power level
Nasby
Ohio
In reading the specs of the CDM 1250 I've noticed an adjustable power output of up to 60 watts or something like that. Do ALLof these units have the capability for that power output or are some models limited to a lower output?
Also, is the output level selected thru the CPS?
Thx in advance.
davidgcet
60W of rated power is the low band models. the VHF is 45W and UHF is 40W. you can turn power up/down via the tuner software, and set hi/lo power modes via CPS. it is NOT advisable to turn a 40/45W unit up to 60W even if it will do it, you will burn out the final a lot quicker. it coudl happen after a few minutes of TX or it could be a few years down the road, but it will happen sooner than if you ran it at rated power.
Laxplurr06
Boston, MA
I was able to change the high/low power settings on my CDM1250 through the CPS. I can change the power to any number I choose as long as it is below the radios high limit. For example I was able to change the high power to 17 watts and the low to 3 watts.
