CDM 1250 problem
kuiperjake
Three Rivers, Mi
So I Programmed a CDM 1250 VHF. This is the first one that I have done. The problem is when I key up I can Transmit but I cant receive anything. Anyone have any idea what the problem is? Please and thank you in advance.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Without knowing how the radio is programmed, any thing any of us might offer would be pure speculation.
If you could post a screen shot of the personality and the zone assignments, it would be a start.
kuiperjake
Three Rivers, Mi
Hope this helps some.
Sorry little new to all of this. Here is screenshots of what you asked. When playing around with it I can receive on a direct Freq but the repeated one wont receive from another radio on the same channel. I can transmit and receive on any other channel that's a direct one. I also programmed a XPR 4550 with all the same freq and they work fine.
clbsquared
Isle of Wight County
Two things come to mind. You either have the wrong receive frequency or pl/dpl tone is wrong. However, (as noted above) without knowing how the radio is programmed, any advice is going to be a guess.
Sent from my HTC One A9 using Tapatalk
Is it a repeater your on? Different TX and RX frequencies, pl, dpl or csq? Is the mdc and perosnality set to and or and or in mdc? Either a codeplug or screen shot to someone may help you more.
jim202
New Orleans region
One thought comes to mind here with your question for help.
Just how far are you from the repeater when your doing a test?
Is the other radio your trying to listen to close to the radio your trying to key the repeater with?
The reason I ask is if your any distance from the repeater, your probably swamping the receiver on the second radio you trying to use as a monitor. The closer the second radio being used to monitor the first radio, the more your going to swamp or de-sense the second radio receiver.
You may have other problems, but it always helps to point out a simple fact that most forget about.
Like has already been mentioned, the way you set up the squelch in the radio will also cause a problem. The use of the and / or selection, along with maybe the confusion of including MDC selection can cause major issues trying to receive signals. Take another look at this area and see if you might have over looked how a selection was set.
