CDM 750
ve9jmc
Saint John, New Brunswick
I have a Motorola CDM750 that was planned on being a dispatch radio. Now this radio is a 25-40 watt VHF version. Is there anyway that it can be converted to a 1 -25 watt version. I'm asking as the dispatch location cannot exceed 10 watts ERP so i would like to be able to set the radio for 7 watts. After my calculations 7 watts with the losses of the coax and connectors and the gain of the antenna would equal out to be 9.88 Watts ERP.
Thank you.
Different boards.
1-25w IMUD6014
25-45w IMUD6015
I've never tried turning a high power radio down below 25 watts. I've heard rumors they tend to get really weird if you attempt to lower the power too far.
These radios are cheap online. I've been buying both 1-25 watt and 25-45 watt VHF CDM's for anywhere from $75usd to $100usd.
By the time you purchased the board to swap it out (if you could find one), it would probably be cheaper to just get the right radio.
ve9jmc
Ok thank you.
I wasn't sure if a change in programming or code plug would enable the 1-25w settings or not. I'm in Canada so it would probably cost me more to get 1 here.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Ok thank you.
Lots of Canadians use those radios, too. I've seen no real differences in prices on either side of the border.
