CDM Headset question???
MDFR_TCOMM
I figured asking here first before searching.....
I have a project that a Plantronics headset must get connected to a Motorola CDM, the ones used by dispatchers, with the two LARGE prongs. Plantronics makes them with and without foot switch control, and I'm looking for latter if posssible.
The Digital tone remotes (MC3000) have an interace for these headsets but I can't get a straight answer from M.
We figured that if this interface is easy obtainable, the dispatchers can remotely go to a localized event and connect their issued headset to a smaller radio versus an expensive consoltte setup.
Thank you in advance,
mdfr_tcomm@yahoo.com
trlrdrdave
decatur, al
I don't see why it wouldn't if I understand your question. Hook the remote to the radio plug the headset into the remote start talking. Unless there is more to it it will work.
