CDM/HT1250 priority question
ryan81986
Ok so I want my HT1250 and my CDM750 to scan and have the first channel be priority. However whenever the priority channel comes on it beeps which can get very annoying. Is there any way to disable the beep but still have it scan with priority?
ems170
Connecticut
Go into the radio configuration in the cps. You will then select the scan tab. In the box labeled scan alerts disable the priority scan box. Save and upload to the radio.
RKG
If these are working radios, having any channel set as Priority 1 other than "SelCh" can get dicey if you try to maintain a conversation with someone while the radio remains scanning.
