CDM invalid fields
nhfdcadet
CETsr
New Hartford, Ct
I have a CDM codeplug giving me these two invalid fields
When I click on them, it gives me this
so, any idea what these might be so I can correct them?
Or am I screwed and have to start again where I started yesterday?
crazyboy
NJ
Any chance you tried saving it, completely closing cps, and then reopening it?
K2NEC
5F6
I had a problem like that and I had no idea what was wrong. I ended up closing the codeplug and starting over. That fixed it IIRC.
crazyboy
NJ
cant save a codeplug with invalid fields
Ah, yes forgot about that in the older CPS. Need more coffee! I know I have had those fields before, don’t remember ever finding what caused them.
nhfdcadet
CETsr
New Hartford, Ct
that's what I ended up doing too, luckily this was a modification to an existing codeplug, not writing one from scratch.
I tried to replicate the problem, and it seemed to appear when I deleted an un-used MDC system, however every personality, and every MDC Call, had the other MDC system selected, I couldnt find any other place for it to be selected, and of course the CPS was no help, just gave me that error when I clicked on it.
I guess it wont be harmful to leave the other MDC system there, it was in the radios when I first read them from whoever wrote the codeplug before me, and it shall live on
K2NEC
5F6
A few months ago I had a problem with "ghost invalid fields", where I attempted to write a radio but was unable to because of invalid fields. When I went to go see what the invalid fields were, there were none that showed up. Never understood why that happened.
Firebuff66
CT
It happens when you delete a signaling system before removing the system from the personality
mikegilbert
MHz so good
Los Angeles
If you've copied and pasted cells from a spreadsheet, there are invisible characters which need to be deleted. They'll show invalid, but won't tell you where. I learned that the hard way after completing a MASSIVE codeplug.
nhfdcadet
CETsr
New Hartford, Ct
Even if I change every personality TX and RX to MDC-2, and every MDC Call to system 2, it still gives me this when I delete system 1.
I'll just leave it there and live with it I guess, I was just trying to tidy up the codeplug a bit
