CDM1250 help
RadioChief55
#1
I'm programming a CDM1250, I have it set to scan and it does when I'm on conventional personality 1 only. On any other personality, it stops scanning and if I hit the scan button, it gives me the low beep indication it wont do it. I'm sure I'm missing something simple.
John
N1GTL
CT
#2
You have to select which scan list you want it to use under EACH personality. Chances are it is set to disabled on everything but the first. Look under the scan tab.
RadioChief55
#4
Ok, I have another question. I have scan lists set up. Is there a way to pick the scan list you want or does it scan the channels that I have in programmed in the scan bank that I have the radio channel set to?
I have it on zone 2 and the channels in the scan list associated with zone 1 aren't scanning.
Thanks John
RadioChief55
#5
Other issue I just found.
When I had one scan bank and one zone, it scanned. Now that I have two, it doesn't scan on either bank.
