CDM1250 Low Band
King City, CA
#1
I have a few of these radios and really would like to move them up to 6mtrs. Have the Pro Series programmer that has been modified for opening the frequencies, but when I create a code plug above 50mhz, it says it has loaded but when I read it it is back at 50 for the upper limit. Can anyone assist or know how I can accomplish this. Hate to waste these radios, all are remote head and in great condition.
wcu02mpa
Asheville,NC
#4
CDM-1250 HAM low band yes
Send me a PM. I can put them into 6M and 10M. I had to hack the hell out of the CPS but I can do them. All I have done are reliable to 54 MHz receive and 53 MHz TX. The low split ones are good down to 29.30 MHz. The deviation has to be brought up a little but that is also doable with global tuner (which I can do)
