CDM1250 Squelch
#1
Where/What is the setting to adjust the squelch in the CPS software for the CDM1250? We got a new radio with the same freqs we have been using for years and now it's picking up (barely braking squelch) transimitions from ??? where. I'm somewhat familiar with the CPS software as I have adjusted the scan lists / personality... however, I'm not sure about the squelch.
NJ USA (Republic of NJ)
#2
The squelch adjustment is not in the cps application, but rather in the tuner application.
I would not suggest makiing any adjustments unless you know what you are doing.
Such adjustments are usually made with a service monitor. If you have one and know
what you are doing then the tuner app is what you seek.
#3
Hmmmm
Was this a new radio out of the box? I've done well over a dozen so far, and never touched any squelch settings while programming the radio. Wonder if you have an issue unrelated to squelch settings?
Are you saying that you are recieving faint unwanted transmissions? Maybe they were there all along, and your old radios didn't have as good recieve as your new radio. Instead of putzing with the squelch, maybe you should look at using PL's.
#4
Yes, this is a new radio... and yes ther are PL tones on the the channels (two different) in question. Like I said, they are barely breaking squelch and it seems like having the squelch turned up just a bit would get rid of it.
#5
New Neighbors
Sounds to me like there are people with the same PL as you sharing the same frequency. Like I said before, with the old radios you couldn't hear them. I don't go back to work until Monday, I'll play with a CDM and see what I can find. Maybe I'll learn something new.
