CDM1250 to 3.5 mm
danielbts11
W2DJB
Gloversville, NY
Hello, anyone have any ideas on how I could get an 3.5 mm aux cord to output out of a CDM 1250? I’m trying to setup the two tone paging system with I am responding for my fire dept without running a new antenna for a scanner that already has a 3.5mm connection.
Thunderknight
Bletchley Park
On the rear 20 pin connector:
Pin 11 = Flat RX audio
Pin 7 = Ground
You can go on E-Bay and buy the pre-made connector, as above, or buy the 16 or 20 pin connector and roll your own.
MRE1032 on E-bay makes good stuff. You won't go wrong with that.
cmdrwill
So Cali
Reminder: The speaker audio output on these CDM radios can not be grounded, or you WILL blow out that little audio PA chip.
What you need is Filtered audio and that goes to the PA amplifier. The listed 'adapter' has a audio isolation transformer.
danielbts11
W2DJB
Gloversville, NY
One of these
So I finally got it all connected today, but it seems it's constantly playing static is there anyway to adjust the squelch?
Thunderknight
Bletchley Park
It's been a while...but I have used that same adapter for recording output and it did not have unsquelched output that you are experiencing.
Perhaps in CPS, Radio Configuration, Accessory Configuration tab, try setting "RX Audio Type" to "Filtered Audio" if it's currently set to Flat.
cmdrwill
So Cali
Filtered Audio is the receiver audio that is demphasized and squelched.
That is the same as the receiver audio before the volume control.
That IS the setting you need. That IS in the CDM programming software.
danielbts11
W2DJB
Gloversville, NY
Yeah I tried that and was hoping that would fix it, but it didn't. I order a new cable, I'm starting to think the one I got was bad
Floridarailfanning
East Tennessee
There should be an option for "Squelched" and "Unsquleched" audio in addition to the Flat and Filtered option. I have used that cable and another before and Flat with Squelch is what worked best.
a417
Make sure frequency and Squelch type (PL/DPL) are correct in the Basic tab. Tab over to Options, and look for the Unmute/Mute Rule below, and adjust based on what you need. I usually used "And Unmuting, Or muting" which will open the audio path with carrier on freq & PL/DPL (set in Basic tab prior), and then close it with drop of either carrier or loss of PL/DPL.
WR9A
Lafayette, IN
In addition to setting the RX Audio Type to Filtered Squelch (or Flat Squelch), you'll also need to set the individual conventional channel(s) you wish to monitor to the proper Squelch Type (e.g., CSQ, TPL, DPL). You'll find the Squelch Type in the RX Settings for each conventional channel you program.
