CDM1250
Philly Metro,PA
#1
I have a cdm1250 (aam25rkd9aa2an) with a corrupt codeplug and did not save the original one now will not read in cps does anyone have same model that could send me the a codeplug doesn't matter what's on it as long as I could re write it and get the radio back to working status would be appreciated thank you
Socal
#3
If your CPS is installed correctly, you will find sample codeplugs for all models of mobiles and portables in a sub-folder labeled SAMPLES on your computer. C; ---> Program Files ---> Motorola ---> Professional Series CPS ---> Samples
I found this on a similar topic from a couple years ago. From a knowledgeable RR user/contributed.
Philly Metro,PA
#4
Thanks for the input still can't get it going found a radio with same model number and tried to write it and didn't work someone said it had to be blank I'm unsure what else to do at this point might have become a paper weight
