Yeah, those will work. But not 150 amps.
For that radio, it'll only need 15 amp feed.
On my personal and work truck, I put in a 60 amp breaker with 6 gauge wire to behind the seat. From there it attaches to a fused distribution block to feed individual radios.
The breaker/fuse value needs to be sized correctly for the load as well as the conductor size. Unless you are running large cable, stick with the Motorola factory harness.
