Cecil County Configuration
shajen
Elkton, Maryland
I own a Uniden BCD396T scanner, and I would like to configure the correct info. into the scanner. It is referenced as EDACS, but when I go to input the info. it asks whether it is WIDE, NARROW, and other information that is not listed on the sheet. Could someone steer me in the right direction as to the proper way to program my scanner for Cecil County? Thank you
North East, MD
Cecil County is a EDACS system with Provoice. There is no current scanner on the market that can scan it. You are limited to the dispatch frequency only.
While at your computer you can monitor dispatch and the ops channels via Teamspeak or livefirefeeds.com. If you have a smart phone or Blackberry there are a couple ways you can scan the same channels via phone.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Not possible - Cecil uses Pro Voice and it can't be monitored by anything, even the new generation XT and GRE scanners. If it was just ESK, that would be doable, but it's not 73 Mike
