Cell Site Question
KR7CQ
Phoenix
#1
Hope I'm not posting in the wrong place, but I couldn't find a forum that seemed to fit any better.
I have what I think is a cell tower that was installed a block from my house this morning, but I'm not sure what it really is. It has a mast maybe 25' tall, and at the top there is a white cylinder, about a foot in diameter, and maybe 2' long. I have not seen this sort of thing installed in residential neighborhoods before, so it has me wondering. It looks nothing like the cell sites that I typically see. I've heard that as 5G rolls out there will be sites everywhere in a much more dense pattern than what has been used up until now, but I've heard nothing about Verizon testing 5G in Phoenix at this time. I am sincerely hoping that this thing doesn't transmit in the 700 MHz band as I have noticed some unusual issues with monitoring 700 MHz systems that are not normally a problem, just today actually. At this point I don't know that this new tower has anything to do with that, but I'm curious.
KR7CQ
Phoenix
#6
OK, I got closer and this thing is on a light pole...I don't even know if it is a transmitter site, the case seems all metal, but I don't think it's a light or speaker or any type of camera, I'm baffled...but here it is...
Point Nemo.
#8
Looks similar to what Verizon has been installing locally on top of utility poles.
They are a small cell site, designed to improve coverage.
Probably will have 700MHz LTE in it, but they don't run the same power levels as a macro cell site.
KR7CQ
Phoenix
#9
Bummer...that would explain the sudden change in reception of 700 MHz systems with my SDS200. It would also explain why my Verizon LTE speed at the house seems to now be a good deal faster after a few speed tests of my LTE internet connection. Three systems I scan went from 90% decode to 5% just today, and this thing was finished mid-day. It all makes sense now. Luckily my most important systems seem to be working on initial testing.
Still, I'm surprised at the metal shield around the antennas. I would think that would block signal? And the irony of being a Verizon customer with newly improved LTE at the cost of having this thing for a neighbor that will disrupt my hobby doesn't escape me.
Point Nemo.
#10
It's not metal. Or at least not entirely metal. The bottom skirt may be, but the top half is an RF transparent material.
Point Nemo.
#12
The latest edition of AGL magazine came in the mail today, and flipping through it….
Charles Industries SHRD1 Pole-Top Radio Shroud matches that photo.
http://www.charlesindustries.com/shroud_ordering_guides/SHRD1 Ordering Guide.pdf
So, what you are seeing is the cover/enclosure shown above (in white).
What's inside is the Small Cell remote heads and a canister style antenna on top.
Which carrier it is is probably indicated by your increase in Verizon performance.
