centra health DMR
Nowhere near a paved road, away from the maddening
#41
Liberty University (Digital)
Took some time yesterday and grabbed all the FCC license data on Liberty University in Lynchburg, and did some monitoring today while I was running errands over in the Burg today. The attached PDF is the result of that effort.
I takes some of the UNKNOWNS posted earlier in this discussion and gives them a home.
I am using this document, in its spreadsheet form as the seed for cataloging all the DMR-NXDN-TRBO stuff in my area, which will be posted later.
Mark C.
Lynchburg Va
#42
well i have still been in search of the missing LCN with no luck.. im beginning to think its because it is a multi site between 2 hospitals is the reason for my dilemma. like i said it is very listenable in spite of something not quite right. i also changed my squelch mode in scanner to "all" and ran a few recordings and found out that a lot of the other frequencys in the system are conventional.. one they use to page rooms for baths and meds that has a ctcss tone. another that I am unable to identify what the use is that uses DCS tone
Ghstwolf62
Clifton Forge Virginia
#43
Wow, never thought of doing that Drum. Just had it on digital only. Will have to try that for next time I hit Lex. Thanks for the info but sorry you're still having trouble with that last one.
I do wish Uniden doing DMR would have auto LCN like my GRE 600 does on appropriate systems.
They don't even do it for LTR from what I understand which is beyond annoying after all these years of it being available.
Lynchburg Va
#44
these 2 are conventional 467.4875. Tone C74.4 is room bath calls and response to bed
call button
466.8500 Tone DCS731 I can't figure out what they are doing but is also part of centra
Sent from my VS986 using Tapatalk
#45
call button
Just checked FCC on both of those frequencies.
No record past or present for anything licensed in Lynchburg.
But alas, that is nothing new.
Lynchburg Va
#47
TGIDs I have so far
101= Security
201= unknown
301= Maintenance
401= CT/Radiolgy/Ultrasound/MRI
402= Patient Transportation services
