Central Midland Railway frequency
Florida
#1
Does any one have the road channel or frequency for the Central Midland Railway in St Louis ? Did a database search and came up empty.
PJH
Global Database Admin
#2
If not listed here - try FCC records or use the database FCC unidentified records feature of the database.
PJH
#3
Central Midland is owned by Progress Rail.
Its headquartered in Minnesota, and is partnered with Great Western, which has its own set of assigned channels in both states.
Doing some digging the most likely freqs are:
160.35
161.19
161.22
161.265
161.28
161.46
161.115
