Change alert on bct 15?
ob123
NJ
Hello, is their a way I can make my own alert on the bct-15 for the fire tone out? Like my own alert sound?
spooney
Indiana
Yes, each of the ten fire tone-out settings has a Set Alert option. Default is Off and you have nine different Alert Tones you can use. After you set the Alert tone you want to use then select Set Level to adjust the volume.
