change over to digital
When any given department in KS goes from analog to digital, does that department get a new frequency & get a department tag ID # ? Thanks for the time, jbxfire
change over
NEC911: Sorry i did not make my self clear. If any department say in Leavenworth,Ks ( fire,police,ems )
goes from analog to digital P25 program, doe's that department get a new frequency # & do they get what is called a
Department Tag ID # also ? Thanks for the time, jbxfire
PVPD730
Yes, they will be assigned a talkgroup ID if they switch over to the KSICS system. The text tag will be whatever the database admins decide to type in. As far as getting a new frequency...no, they will likely be heard on the Leavenworth County Simulcast Site of the Statewide system.
