Changes for Cumberland Co P25 Phase II TRS
milf
Careful, I CAN hear you!
Indianapolis, IN
#1
New contact, APCO, changed from an Carmel, IN agency...
New freqs
YW WQFA621
1 - CECC, 42 SOUTHBEND DR, CROSSVILLE (CUMBERLAND) TN [Structure: Mast] (map)
[Antenna 1 - HTT: 32.0m, Polarization: Vertical, Beamwidth: 360.0°, Gain: 9.0dBi, Azimuth: 360.0°, HAAT: 46.4m]
[Antenna 2 - HTT: 35.0m, Polarization: Vertical, Beamwidth: 360.0°, Gain: 6.5dBi, Azimuth: 360.0°, HAAT: 150.0m]
453.65 FB8 Ant: 1 40p 100e Units: 1 11K2F3E 8K10F1E
460.6125 FB8 Ant: 2 100p 200e Units: 1 Pagers: 100 9K80D1W 9K80D7W (P25 Phase II)
460.1125 FB8 Ant: 1 40p 100e Units: 1 11K2F3E 8K10F1E
460.3125 FB8 Ant: 2 100p 200e Units: 1 Pagers: 100 9K80D1W 9K80D7W (P25 Phase II)
460.2125 FB8 Ant: 1 40p 100e Units: 1 11K2F3E 8K10F1E
460.4375 FB8 Ant: 2 100p 200e Units: 1 Pagers: 100 9K80D1W 9K80D7W (P25 Phase II)
460.0875 FB8 Ant: 2 100p 200e Units: 1 Pagers: 100 9K80D1W 9K80D7W (P25 Phase II)
460.625 FB8 Ant: 1 40p 100e Units: 1 11K2F3E 8K10F1E
2 - TURKEY KNOB, DARTMOOR RD, FAIRFIELD (CUMBERLAND) TN [Structure: Guyed] (map)
[Antenna 1 - HTT: 86.0m, Polarization: Vertical, Beamwidth: 360.0°, Gain: 9.0dBi, Azimuth: 360.0°, HAAT: 152.6m]
[Antenna 2 - HTT: 113.0m, Polarization: Vertical, Beamwidth: 360.0°, Gain: 9.8dBi, Azimuth: 360.0°, HAAT: 180.0m]
460.3625 FB8 Ant: 1 40p 100e Units: 1 11K2F3E 8K10F1E
460.6125 FB8 Ant: 2 54p 85e Units: 1 Pagers: 100 9K80D1W 9K80D7W (P25 Phase II)
460.125 FB8 Ant: 1 40p 100e Units: 1 11K2F3E 8K10F1E
460.3125 FB8 Ant: 2 54p 85e Units: 1 Pagers: 100 9K80D1W 9K80D7W (P25 Phase II)
460.2875 FB8 Ant: 1 40p 100e Units: 1 11K2F3E 8K10F1E
460.4375 FB8 Ant: 2 54p 85e Units: 1 Pagers: 100 9K80D1W 9K80D7W (P25 Phase II)
460.0875 FB8 Ant: 2 54p 85e Units: 1 Pagers: 100 9K80D1W 9K80D7W (P25 Phase II)
3 - CAMPBELL JUNCTION, 4800 FT E OF PLATEAU RD EXIT OFF I-40, CAMPBELL JUNCTION (CUMBERLAND) TN [Structure: Guyed] (map)
[Antenna 1 - HTT: 61.0m, Polarization: Vertical, Gain: 9.0dBi, Azimuth: 360.0°, HAAT: 120.1m]
[Antenna 2 - HTT: 124.1m, Polarization: Vertical, Beamwidth: 180.0°, Gain: 8.0dBi, Azimuth: 294.0°, HAAT: 173.0m]
460.2625 FB8 Ant: 1 40p 100e Units: 1 11K2F3E 8K10F1E
460.6125 FB8 Ant: 2 40p 125e Units: 1 Pagers: 100 9K80D1W 9K80D7W (P25 Phase II)
460.3125 FB8 Ant: 2 40p 125e Units: 1 Pagers: 100 9K80D1W 9K80D7W (P25 Phase II)
460.4375 FB8 Ant: 2 40p 125e Units: 1 Pagers: 100 11K2F3E 8K10F1E
460.0875 FB8 Ant: 2 60p 158e Units: 1 Pagers: 100 11K2F3E 8K10F1E
4 - MIDWAY VFD, NEWTON RD 15 MI SE, CROSSVILLE (CUMBERLAND) TN [Structure: Mast] (map)
[Antenna 1 - HTT: 52.0m, Polarization: Vertical, Gain: 9.0dBi, Azimuth: 360.0°, HAAT: 131.0m]
[Antenna 2 - HTT: 52.0m, Polarization: Vertical, Beamwidth: 180.0°, Gain: 8.0dBi, Azimuth: 204.0°, HAAT: 131.0m]
460.1875 FB8 Ant: 1 40p 100e Units: 1 11K2F3E 8K10F1E
460.6125 FB8 Ant: 2 60p 158e Units: 1 Pagers: 100 11K2F3E 8K10F1E
453.85 FB8 Ant: 1 40p 100e Units: 1 11K2F3E 8K10F1E
460.3125 FB8 Ant: 2 60p 158e Units: 1 Pagers: 100 9K80D1W 9K80D7W (P25 Phase II)
460.4375 FB8 Ant: 2 60p 158e Units: 1 Pagers: 100 9K80D1W 9K80D7W (P25 Phase II)
460.0875 FB8 Ant: 2 60p 158e Units: 1 Pagers: 100 9K80D1W 9K80D7W (P25 Phase II)
9 - BLACK MOUNTAIN, OWL ROOST RD 2.7 MI SSW, CRAB ORCHARD (CUMBERLAND) TN [Structure: Guyed] (map)
[Antenna 1 - HTT: 70.0m, Polarization: Vertical, Gain: 2.5dBi, Azimuth: 360.0°, HAAT: 361.6m]
[Antenna 2 - HTT: 82.0m, Polarization: Vertical, Beamwidth: 180.0°, Gain: 8.0dBi, Azimuth: 105.0°, HAAT: 372.0m]
460.6125 FB8 Ant: 2 82p 125e Units: 1 Pagers: 100 9K80D1W 9K80D7W (P25 Phase II)
460.2375 FB8 Ant: 1 23p 56e Units: 1 11K2F3E 8K10F1E
460.3125 FB8 Ant: 2 82p 125e Units: 1 Pagers: 100 11K2F3E 8K10F1E
453.6875 FB8 Ant: 1 23p 56e Units: 1 11K2F3E 8K10F1E
460.4375 FB8 Ant: 2 82p 125e Units: 1 Pagers: 100 9K80D1W 9K80D7W (P25 Phase II)
460.0875 FB8 Ant: 2 82p 125e Units: 1 Pagers: 100 9K80D1W 9K80D7W (P25 Phase II)
11 - FIRE TOWER ROAD, ROCKWOOD (ROANE) TN [Structure: Lattice tower] (map)
[Antenna 1 - HTT: 49.0m, Polarization: Vertical, Beamwidth: 180.0°, Gain: 8.0dBi, Azimuth: 270.0°, HAAT: 252.7m]
460.6125 FB8 Ant: 1 45p 158e Units: 1 Pagers: 100 9K70D1W 9K80D7W (P25 Phase II)
460.4375 FB8 Ant: 1 45p 158e Units: 1 Pagers: 100 9K70D1W 9K80D7W (P25 Phase II)
460.0875 FB8 Ant: 1 45p 158e Units: 1 Pagers: 100 9K70D1W 9K80D7W (P25 Phase II)
460.3125 FB8 Ant: 1 45p 158e Units: 1 Pagers: 100 9K70D1W 9K80D7W (P25 Phase II)
rkm1215
Knoxville
#2
Attention line indicates: ATTN Louis A. Cartwright which means Cartwright Communications out of Knoxville is involved.
460.3125 is no longer licensed.
Site freqs per FCC DB:
1. 453.2625,453.4125,453.65,453.9,460.0875,460.1125,460.2125,460.4375,460.6125,460.625
2. 453.2625,453.4125,453.9,460.0875,460.125,460.2875,460.3625,460.4375,460.6125
3. 453.2625,453.4125,453.9,460.0875,460.2625,460.4375,460.6125
4. 453.2625,453.4125,453.85,453.9,460.0875,460.1875,460.4375,460.6125
9. 453.2625,453.4125,453.6875,453.9,460.0875,460.2375,460.4375,460.6125
11. 453.2625,453.4125,453.9,460.0875,460.4375,460.6125
