Mike_Alpha
Is there a quicker way to enable/disable trunk systems in a TRX-2 without having to go into the menu and lock one or more trunk systems out to select between them. I can select scan lists easy enough, but haven't been able to work out how to have the trunk systems selectable with minimum key presses. With most Uniden scanners a press of a button will select or remove a system.
I like to have North, South, East and West systems to cover my city and switch between them as I drive around, but with the TRX-2 I have to pull over and poke around in the menu chain to enable one or more.
Mike
Mike
