changing frequencies
Minnesota
#1
TRX-! When wanting to add or take away a frequency from a already selected county, what is the process?
When pushing the SKIP button, it will just lock it out temporary, unless you have it set on on, . then it will eliminate it completely, is that correct?
Does the trx-1 have any kind of a range setting?
