changing frequencies
rheroff
Minnesota
Now that I have had my TRX-1 for a couple weeks, I want t get rid of some frequencies, and add some frequencies in my scan lists. I have it set up the Preferred Method through the computer. Any advice on how to perform this process. Explain to me step by step, would be very helpful....
Thanks, RON
Are you changing conventional or trunked systems?
Either way, if you go to the conventional freq list in the software you can manually add or delete there. Look on the right side for the delete button when you highlight a freq. Look in same place for add button.
For trunked systems you could delete the system and add it again with the changes, but it's probably easier to manually add/delete sites or tgid from the screens on the trunked system tab.
Sent from my LGLS775 using Tapatalk
