Changing modulation in a quick search
Avery93
Marion County, AL
With a BCT-15, is there an easy way to change the modulation while holding on a frequency in a quick search? Right now the only way I know how is to quick save the freq and then change the modulation through the regular menu. This isn't exactly easy or fast, and leaves me with an unwanted saved frequency.
dracer777
South Dacono, CO
Wirelessly posted (MOT-QA30/00.72 UP.Browser/7.2.7.5.610 (GUI) MMP/2.0)
On my 396xt, while holding, i push func, the 9 which is labeled "mod". dunno if its the same on your scanner.
Avery93
Marion County, AL
Nope, that turns on some "Alert+" thing. I've pressed every button with function on and none of them change modulation or do anything really useful for me. Thanks anyway though!
dracer777
South Dacono, CO
No problem. I'm sure someone will have an answer for you. Good luck.
Avery93
Marion County, AL
Well its been 2 days and no one has responded. Surely someone knows a better way if there is one. Anybody? UPMan??
