Channels Missing XTS 2500
sunshower21
Has anyone ever had a radio magically loose channels? I have an XTS 2500 that is suddenly missing the first 4 channels in only one of the zones. When I read it, all of the channels are correct and as they should be. I've tried rewriting into it and also cloning it with a template I knew for a fact was correct. Is this an issue anyone has dealt with?
firephoto184
I’m having a similar problem on my APX7000 the first and 16th channels are now the same as the 3rd channel. Also only on one zone. When I read it it shows what should actually be programmed in there.
rescue161
KE4FHH
Hubert, NC
If the test that MTS2000des mentioned shows that the selector switch is bad, they can be changed, but they are a pain in the butt. I can't tell you how many I've done over the years. It is one of the main reasons why I never really liked the 2500. That along with the SMA, volume and the side buttons that are soldered directly to the main board.
